im going to be trading my camaro for a 65 Nova (im sad too, i just dont have the money to finish it)...my question is, i just swapped in a th-400 tranny but i dont have the kickdown or vacuum lines hooked up. the guy just wants to see my car drive before we trade and i know that i can drive it w/o the kickdown but what if i dont attach the vacuum line? can i just put it in 1st and manually go through the gears just to give him a ride in it? im asking because i dont have the connection that taps into the manifold. my previous tranny had a full manual valve body.
[This message has been edited by jvolk81 (edited 12-09-2001).]
Doesn't your carb have a manifold vacuum port? You can connect it there, or tee into whatever line is already connected there.
JohnZ
'69 Z28 Fathom Green
[This message has been edited by JohnZ (edited 12-09-2001).]
Discussion Starter · #6 ·
another question....i connected the vacuum line to the port at the base of the carb...holley 750 double pump...i dont have a driveshaft in it but i manually put the tranny in drive. If i rev the motor up w/ it in drive will the tranny shift w/o the shaft in it? it didnt shift when i tried this.
