Does anyone have any information on where the TI amplifier mounting plate was intended to be mounted? I have heard the 69 asembly manual shows the way it mounts. I understand it bolts to the vertical hood latch support panel located beneath the catch assembly. Does anyone have a GM drawing showing how and where it mounts?
There are TI engineering assembly drawings associated with COPO 9560. The amp is mounted to a plate that is mounted on the latch support. I borrowed and copied an NOS mounting plate for our ZL-1 project and made a drawing of it. I also have copies of the mounting instructions should you need them.
You're aware TI needs full time 12v. Requires a wiring jumper.
William, Thanks for the reply. I have my TI system set up and functioning now. I'm trying to figure where the recommended mounting location is. I would be very interested in a copy of the instructions. If you want to email that would be fine. I am willing to pay costs if you photocopy and send one to me. Reply by email if you like. Thank you![/B][/QUOTE]
[This message has been edited by sunocospecial (edited 11-07-2001).]
