1 - 12 of 12 Posts
I don't think that the TH350 will work with the TH400 crossmember... it will work with the Powerglide crossmember though!
part # CM-1 through Rick's First Generation Camaro. Don't know if it is reproduction or not though...
The 400 cross member in more tubular, and has the mounting holes back farther. Not sure, but judging from the picture, the mounting holes are also lower to the ground than the others.
Ricks lists CM-1 as "Call" which almost always means used.
1 - 12 of 12 Posts
