I am looking at buying this Camaro. The owner says it has a Turbo 350, but please look at the pics and hopefully someone can confirm what it is. The shift lever indicates to me it's a Powerglide. :confused: Thanks, Kevin
looks like a th350 to me...you can tell by the pan...cut off on the rear corner of the pass side...the shifter in the car doesnt mean anything ...could be that the guy wanted to keep the car looking stock...th350 for sure...
Plus, the band apply servo (the piston the round cover covers) is at the front on a PG.
There may be an extra notch filed in the shifter.
Good Luck!
Yes. RS option was a Trim package only, regardless of drivetrain.
As said, THM350 with Powerglide shifter. Not a problem, I've done it when I was running a THM350. Now I'm back to a 'Glide.
