What is the difference between a bb 4 speed cross member mount and a sb 4 speed crossmember mount?
<BLOCKQUOTE>quote:</font><HR>Originally posted by GMJim:
The mounting position.
Jim
<HR></BLOCKQUOTE>Does the mount put the tranny tail higher or lower or are they the same height or are the two bolt holes for the mount are just different
Smuth66
Sorry! Should have read the post a little closer. Most people ask about standard and automatic. There is no difference between big block and small block Standard transmission support braces. Same part number 1967 #3870182 1968-69 #3895830
Sorry
Jim
[This message has been edited by GMJim (edited 11-20-2002).]
Sorry Guy's
Got this backwards. The support, frame to frame IS the same #3899006 The mount for 67 is #3870182 68-69 is #3895830
Jim
Sorry Guy's
Jim I have a parts book from D&R parts and they show two different parts for a bb 4 speed and sb 4 speed cross member I'm not talking about the rubber mount I'm talking about the steel plate that bolts underneath the tranny frame to frame. One side of the bolts is sloted and the other side is not. Does the slotted side go on the drivers side frame or passengers side If they are the same mounts the two bolt holes for the rubber mounts do not line up
<HR></BLOCKQUOTE>
I will check a little closer. I have an original GM parts book. I got this all messed up by not reading it properly, and thought I had it straightened out! I'll get back to you.
Jim
I have checked my GM parts book and It says the support (Big steel brace) is the same part number for small and big block # 3899006 The mount (rubber and steel) for 67 is #3870182 for 68 - 69 is 3895830 small and big block. I checked my Rick's First generation catalog and it lists two different support braces (Big steel brace) for 67-69.
My GM parts book is the May 81 version? Don't know what to tell you?
Jim
[This message has been edited by GMJim (edited 11-21-2002).]
