1 - 16 of 16 Posts
guys,
im in the process of ordering my new tremec tko 5 speed.
you guys with tko's.... what shifter did you go with (standard or pro 5.0)?
are you happy with your choice? why/why not?
thanks
what kind of clutch? mccleod?
do you have it in yet? how was the install?
It's not in yet. I bought the Ford version of the TKO for $1349 new. Then I used the McLeod adaptor bellhousing #8635. It's only $85. more than their normal scattershield but comes with the aluminum adaptor to mount the Tremec. Dark Horse Performance supplied the adaptor pilot bushing and the Pro 5.0 shifter with Hurst handle and white ball knob. I am running the McLeod oval track dual disc with aluminum flywheel and center hub. Much stronger than their street twin, much lighter, and will shift well at high rpms. It also will handle 1200+ HP. I'm using a Tilton hydraulic throwout bearing as I have no mounting provisions on the Arias block or Wayne Due subframe for the stock bellcrank assembly. I've got a hydraulic clutch master and bracket coming from Teetoe Jones that bolts up to the stock pedal assembly.
I'll let you know how it goes when it's finished. As I said I've had a couple of these TKO's and have been very happy with them. Tough units that shift very smoothly.
Jody
MY CAMARO
so am i understanding that with a special bellhousing/adapter, i could use a ford tko on my 468?? id love to save 500 bucks! or is there more to it than that?
thanks jody!!
Yes, that's true. McLeod actually sells the adaptor separately from the bellhousing so I don't see why it couldn't be used with a standard stock bellhousing or Lakewood, etc. Their housings are pricey which is why I mention that but I think they're better quality than the Lakewood units.
There's only two issues at that point; because of the spacer the trans would be about 3/4" further back than the modified Chevy versions. No biggie to me. You would also have to modify a Ford throwout bearing to work (which a friend did on the second gen board pretty easily) or run a hydraulic unit like I am. Other than that it will definitely save you some money. I think they're getting about $2000. for the Chevy version and the Ford one is $1349 new from D&D Performance. I had this exact set-up in my Cobra with the 406 and it worked flawlessly.
Jody
MY CAMARO
jody, hmmmm i will definitely look into this today! do you have a link on the board (im assuming nastyz28.com or whatever it is)? or maybe who posted it?
so did you get the "kit" for 1300 or just the tranny? the kit from forte includes speedo cable, tranny fluid, yoke, crossmember etc?
regardless though, the tranny through forte is 18XX... thats 500 more for basically the same tranny....
does the ford version have the same power handling capabilities? (hp/torque)?
thanks jody, youre a great help!
JKS67SS396,
Do you need a trans yoke for your TKO? I have a new one for the Tremec TKO that is un-used, it came with my trans that I purchased from Fortes, you can have it cheap.....My new alumin. driveshaft has 1350 u-joints on both ends (the Moser 12bolt I have uses 1350 a u-joint) so the stock TKO yoke is not needed.
Good luck with your trans install. It is a very simple swap......The hardest part is dialing in the bellhousing.
Larry
There's nothing in the Forte's kit that cannot be done locally.
The speedo cable is easy. Have one made with the tranny side from a 5.0 manual trans Mustang, and the speedo side stock GM. You can have it made to your specs. The speedo shop should also sell the retaining fork used to hold the cable into the trans.
The yoke is just a C6 piece. Cheap.
GM Syncromesh is about $7/qt. It takes three quarts.
The crossmember is the hardest part but if you have some fabrication skills and a welder it can be done in an afternoon. With the adapter plate moving the trans back a bit the Forte's crossmember might not fit.
The only difference between the GM and Ford TKO is the input shaft and the re-drilling of the bolt holes on the case to match the GM bellhousing. Internal components are the same.
The Red Beast http://www.geocities.com/casanoc
Jody asked me to chime in on this one which I am happy to do. I did the Ford version swap on my '79 Z28.
I used the Lakewood adapter bellhousing because I needed an explosion proof unit anyway and didn't own one in the Chevy pattern (my bellhousing was the stock lightweight one that came with the car).
I used a Ford throwout bearing. I wish I could provide a part number, but I can't. I understand that Ford used the same throwout bearing for years and years. What worked for me was going into the local NAPA and asking for a throwout bearing for a 1968 Mustang 289 with a four speed.
You can use the Chevy fork with the Ford bearing if you trim the clip on the fork. You need to "shorten" it on both ends of the "U" shape so it clips over the Ford bearing. Sorta hard to explain via a keyboard, but easy to see when you are holding both parts in your hands. I used a dremel tool to cut off the ends. That's it....just lube the bearing and install.
Oh yeah, you are also going to need a Ford clutch disc (wanna say 10 or 11 spline....I know it is much coarser than the one that came with my Super T-10 tranny).
I got my setup about four years ago from Dark Horse Performance. They are knowledgeable Ford guys and could point you in the right direction with specific part numbers, etc. Nice guys.
Hope this helps some.
I had asked about this before but didn't get much response. So, we're saying a stock tremec can be used with a ford t/o bearing, slight modification to the gm fork and a special bellhousing and/or an adaptor plate is all that is required? What is the tq/hp rating on these units? Seems something has to be beefed up in order to get the "TKO"??
Also, how does the "stock" Ford tremec do with a fist gen console? Can you still relocate the shifter position?
Bret Copsey
'68 Camaro base coupe
'92 Caprice Wagon
'99 Venture Van
[This message has been edited by bretcopsey (edited 10-02-2002).]
Discussion Starter #13
"You need to "shorten" it on both ends of the "U" shape so it clips over the Ford bearing."
got pictures? i dont know anything about this stuff (gonna learn fast though). so you shorten the fork prongs to cradle the ford throwout bearing?
also, your tko is a 10 spline???? the one i was gonna buy is a 26 spline. jody, whats yours? is the ford tko different than the GM tko?
also, carl, do you have a template or measurements for your cross member mods?
did you start with a TH400 crossmember?
thanks guys! youre helping a lot!
The Tremec 3550 (must be what Mike has) uses a 10 spline input shaft. The TKO uses the same 1 1/8" 26 spline that GM uses so a stock Chevy clutch for the above works great. The output shaft is larger on the TKO also but the yoke comes with the trans.
By the way, thanks Mike for the info. I was wondering what the mods were for the throwout bearing. Sounds very easy.
MY CAMARO
[This message has been edited by Camcojb (edited 10-02-2002).]
No dimensions for the crossmember, but fabrication is easy. Just cut off and re-weld the tab on the other side of the TH400 crossmember. Mock it up in the car to center the trans and to get it up into the tunnel as far as possible. But it's a really tight fit. The tab get re-located to the front of the crossmember and is almost too far forward. With the adapter plate it may be too far forward. Same would be true for Forte's part. You may have to section the crossmember to make it fit.
You may want to check the archives on this. The crossmember has been covered in-depth several times.
[This message has been edited by CarlC (edited 10-02-2002).]
Discussion Starter #16
ok, so this is what im gonna buy:
ford tko tranny
mcleod bellhousing 8635
mcleod street twin clutch 64002-7
D&D's bearing
D&D's ball stud, what the heck is a ball stud???
stock clutch fork (to be modded)
turbo 400 CM (mod this too)
speedo cable (mod this too or buy it)
tranny fluid
driveshaft with a ford yoke on one end, chevy on the other
and the bolts to mount it all.
anything else?
thanks guys! youve been a huge help on me and my wallet!
1 - 16 of 16 Posts
