came across a bundle of center caps and trim rings but the rings have no numbers on them. The center caps are 3925805 GW 552504
Ive seen posts that they go to 69 camaro but could they also go to other GM vehicles as well?
Kevin the center caps had those numbers inside them. the rings are hanging on the wall plus some on the shelfs in the pics in bench section where you commented on getting numbers off pulleys, dist, and starters. I will see if I can do that.
None of the rings had any numbers on them that I saw. I know they came as sets but thought original rings should have numbers on them too?
