I have a SBC in a 69 Camaro w/MSD 6AL,Pro billet dist.,Timing retard box.When i drive the car after getting it up to temp. shut it off for 20-30 minutes it will not hit a lick no poping no nothing.After about 2 hrs. or so it will fire right up and run fine until you shut it off again.I called MSD and they told me to mount my Blaster2 coil verticle instead of horizional.I did that and it still had same problem.I replaced the coil, have same problem.What would you replace next? I need a procedure to troubleshoot.Please help!!!!
