I have carpet in mine. I had a stereo unit installed and when the built my amp racks the lined my trunk in black carpet, glued it down, and it looks great!
Bad part about carpet much less glued down, if you have a water leak or get caught with top down , window down or no windows, you will want to pull it all up and get to the metal floor to dry out. But if you can get one thats moulded, then it shouldn't be that bad, just pull carpet up and dry it out. The one on ebay is not that expensive , about double a standard houndstooth repop rubber.
