I am looking on moving the battery to the trunk and I will also need a dieconnect switch.
1) any particuliar company. Looking at Taylor systems on Summitt
2)same on disconnect switch. Also wondering how to mount the switch without doing to much damage.
Any direction would be appreciated. Going to the track soon and need all the advantage I can get.
There are a lot of posts on this and you can get the parts at most local shops if you're willing.
I was going to mount my cut off behing the tag (just remove the tag at the track) but I also have a fuel cell so yours may be different ?
Another option is to mound in the back-up light (use an aftermarket one ;)) ?
on one car i set up, i used the push rod remote switch. ran the rod out through a back up light lens. that way i could replace the lens later and be no trace of it on the outside.
