1 - 2 of 2 Posts
I just came across one pair of 16 x 8 TT II's at Jegs on the used rack for sale for $78 a piece. They had a tire balanced on them but the backspacing was wrong and the guy never used them. Will 4.75" backspacing be too much for either the front or the rear of a camaro. I have drums all the way around but will upgrade to front disc brakes eventually. Not the big brakes just a standard drum to disc conversion kit. The price is amazing on these rims and i like the idea of 16's to have more sidewall. What do you guys think, will they fit? I am also running Caltracs on the back as well.
Thanks, Erik
They should fit fine. For the front you can run a 245/50, the rear a 255/50.
-1/2* camber and as much castor as you can on the front (up to a max of 6*). The rear MAY require a bit of fenderlip rolling from the 10-2 o'clock range. It's not noticable when standing next to the car.
1 - 2 of 2 Posts
