I am sure a lot of you have run into the same situation and I hope someone has a solution.
I will be installing the 2229 booster with the DSE brackets on my 69 camaro. The booster has a long rubber boot that will need to extend through the firewall by an inch or two. I have seen posts where folks have had to enlarge the opening in the firewall so it will fit.
Here is my issue, the rubber boot will not seal against the firewall, just pass through. How do you make this opening weather proof? I do not want water or engine smells getting into the cabin.
Thanks for your help
