So after two months of not driving my car due to a camshaft change a death in the family, I finally got the car running last night. i took it for a drive and as soon as I used the turn signals once I blew the fuse.
I never had this problem before and the only wiring I disconnected was the battery and the MSD box. I blew a 20 AMP fuse and then i put in a 15 AMP because thats all I had and blew that one too.
What should I be looking for to fix this problem??
Thanks, Erik
Discussion Starter #2
Anybody got any suggestions? I replaced the fuse and put a new flasher in but it happened again.
Erik
ttt
Just developed the same problem.
No apparent reason for the failure just started blowing a fuse.
If I replace the fuse the hazards work fine which suggests its not a problem with the bulbs or holders.
Look for corrosion or rust at the fuse terminal, my car did the same thing when I bought it, the resistance created from the rust would build heat and fry the fuse, once I cleaned the terminals of rust and crud, it's all good. 9 times out of 10 with our old cars it will be a poor connection or a bad ground.
It could be a bad switch too, but I'd check all the easy stuff first.
Well, I found the problem as to what was causing the fuse to blow. Stupid me!!! The car was originally a 4 speed car and the back up lights wiring go into the firewall and come out in the engine bay with a two prong connection on it. Well, after doing all this new engine work, my ground strap was actaully laying across these two terminals and blowing the fuses. It took two days and 6 hours to find this simple problem but it is fixed.
Thanks, Erik
