I recently replaced all the wiring harnesses in my 69 Camaro. This included a new fusebox, new fuses. I also replaced the turn signal switch. I cannot get the turn signal to work. The parking lights come on and the hazard lights flash, 2 in front, 2 in rear. Check all connections, etc. Any suggestions will be helpful. Thanks.
Check or change the turn signal flasher can. It's under the dash to the right of the steering column. Buy a 3 dollar one from someplace like Autozone.
Thanks John. After I posted this message I started reading the archives and found out through them that there were two flashers. I wasn't home when hubby took off the old wiring harness, so I didn't see the 2nd flasher. After I read about the 2nd flasher, I told hubby and that started a "yes there is" and "no there's not" war. Of course, I won and had a delicious steak dinner at the Outback Steakhouse. Thanks, your site is fabulous!
