i have a 1993 camaro base model. the turn signal swtich broke and i replaced it today with a new one. i have to scratch my head because after i put the new one in there is nothing the connects the turn signal arm to the switch... what am i missing???? it has cruise and delayed wipers and dimmer.but for the up and down motion there is nothing there..im so confussed. the book shows a little metal bracket called turn signal arm but i cant find it anywhere.
The combination handle slips into a hole on the switch, unless it either was not made onto the switch plate or it was not transferred or the wrong part.
The turn signal lever goes into the wiper switch, witch connects to the turn sig
switch with a "Y" shaped metal tha screws on. Look on the floor, under seat etc,
Are you talking about the switch in the column??? The 93 had a relay and switch.
The metal arm is stuck inside your cruise lever. It shouldn't/can't really fall out. If you need help snap a picture and clarify what you are working on, because the dimmer, delay switch and all those are on the stick but has nothing to do with the operation of the switch.
im a bit confused by this as well, i have some parts that i can take pictres of that the threadstarter might be referring to
i forget what this piece does, but im just seeing if its what you're talking about
this piece is what activates the high beams, it rides on a piece of plastic that is in the last picture
the turnsignal switch just plugs into the hole in the next pic
you push it in, then turn it, and it pops in place
ok, the piece that the high beam switch hits is almost exactly centered in the picture, if you take a look at the red wire, you can see the connector where it holds onto the wire, you can see a piece of plastic directly next to it, and then another one next to that, that is the piece the 'y' shaped thing presses onto to activate the highs
i hope this helped
The top picture guides the metal rod that activates the turn signals. If you are missin a metal rod it should be in some way, shape or form around the bracket in the first picture. I am pretty sure it has a tab on it that would be pretty difficult to have fall out and if you don't have this it would be the reason your signals never worked. Unfortunately that part can only be obtained at the junk yard.
