When i turn on my right turn signal, both turn signal lights flash on front end. What could be the problem
make and model would help but it probably a bad connection (ground) or bulb
welcome to team camaro!!! what kind of car are you working with???????????
I had this problem on my Camaro back in 1968. My brother replaced a turn light bulb in the front with a single element bulb instead of double element. This will make the turn lights do crazy things. Check your bulbs.
