I have a 69, my right turn signal will not flash, I have changed all the bulbs . Could this be a bad flasher ? The left side is working fine. Any suggestions ?
Bad flasher or bad ground on the sockets on that side. Try the flasher first and if that doesn't solve it, with the directional set to blink, use a test light or wire to the body ground and to the metal bulb edge and see if it blinks.
Kev
I would think that the problem would be in the turn signal switch, wiring or as stated a bad ground. I doubt it is the flasher, because the left side would not work either.
