I purchased a 1969 Camaro 2 years ago with a 400 SBC that was supposedly dyno'd at 580 HP NA. The previous owner took it to the drag strip once and said he ran a low 11.xx 1/4 mile time with poor 60' times. The engine was built around 2005 and has ~ 1500 miles of which I put 750 miles on it myself. I would like to go with a LS based engine that would be a more streetable setup. The components to build this engine without machining or labor would cost ~$16,800 today. I am thinking about selling the complete engine air cleaner to oil pan, accessories to flexplate for $8500. Does this sound reasonable?
Disclaimer: The parts listed below is a close approximation of the BOM but may not be the exact part numbers.
Part No. | Description | Qty. | Unit Price | Total |
84031/21 | World Products Motown Cast Iron Block 4.125" Bore | 1 | $3,039.18 | $3,039.18 |
Main bearings | 1 | $75.00 | $75.00 | |
Melling oil pump & pickup | 1 | $60.00 | $60.00 | |
4-400-375-6000 | Scat 4340 Forged Crank | 1 | $694.99 | $694.99 |
CRS6000B3D | Eagle 6.000" 'ESP' H Beam Connecting 4340 Forged Rods with ARP 8740 Rod bolts | 1 | $449.00 | $449.00 |
Rod bearings | 1 | $75.00 | $75.00 | |
231319S | SRP Pistons, 4032 Forged Aluminum, 4.125"Bore, +16cc inverted dome pistions, 1.125" Compression height | 1 | $716.99 | $716.99 |
272-RH | Isky Red Zone Roller lifters, set of 16 | 1 | $734.99 | $734.99 |
12-823-14 | Comp Cams, Mechanical Roller 0.900" base circle Duration @0.050 252/258 0.4210"/0.4200" 106 Degree LSA | 1 | $529.95 | $529.95 |
Cam bearings | 1 | $30.00 | $30.00 | |
Timing Chain | 1 | $100.00 | $100.00 | |
1604-16 | Comp Cams Roller Rockers 1.52, Set of 8 | 1 | $439.95 | $439.95 |
1805-8 | Comp Cams Roller Rockers 1.60, Set of 8 | 1 | $287.95 | $287.95 |
stud girdles | 1 | |||
Pushrods | 1 | $150.00 | $150.00 | |
1008102 | Brodix Track 1 215 heads, 2.08"/1.60" | 1 | $2,842.18 | $2,842.18 |
134-3601 | ARP head bolts | 1 | $85.00 | $85.00 |
1406 | Fel-Pro exhaust gaskets | 1 | $23.99 | $23.99 |
1004 | Fel-pro head gaskets | 1 | $46.99 | $46.99 |
1206 | Felpro Intake gaskets | 1 | $20.99 | $20.99 |
2975 | Edelbrock Victor Jr. Intake | 1 | $392.95 | $392.95 |
85551 | MSD Pro Billet SBC Distributor | 1 | $316.76 | $316.76 |
8202 | MSD Blaster II Coil | 1 | $59.38 | $59.38 |
6425 | MSD 6AL | 1 | $305.06 | $305.06 |
31189 | MSD 8.5mm Super Conductor Plug wires | 1 | $120.56 | $120.56 |
AR-3934 | Autolite Spark plugs | 8 | $5.99 | $47.92 |
9-221 | Cloye's Two piece Timing Chain Cover | 1 | $135.99 | $135.99 |
9483 | Trans-dapt Aluminum Water pump pulley | 1 | $83.99 | $83.99 |
8811 | Edelbrock water pump | 1 | $298.95 | $298.95 |
SS415-1AL | Super Sucker 1" Carb spacer | 1 | $117.99 | $117.99 |
6095 | AED Braided fuel line kit | 1 | $73.99 | $73.99 |
AED 4150 Carb 750HO | 1 | $639.95 | $639.95 | |
Sum-G1327 | Summit dual return spring kit carb | 1 | $13.13 | $13.13 |
6057 | Trans-dapt crank pulley | 1 | $106.99 | $106.99 |
Milodon Deep oil pan | 1 | $300.00 | $300.00 | |
917781 | ATI Super Damper | 1 | $303.24 | $303.24 |
10185064 | Chevrolet Cast valve covers ?? | 1 | $859.40 | $859.40 |
2131-1HKR | Hooker Super Comp longtube ceramic coated | 1 | $937.76 | $937.76 |
Starter | 1 | $150.00 | $150.00 | |
6059 | Alternator Pulley | 1 | $57.99 | $57.99 |
Alternator | 1 | $150.00 | $150.00 | |
20120 | March Alternator Mount kit | 1 | $94.99 | $94.99 |
power steering pump | 1 | $150.00 | $150.00 | |
8934 | PS pump pulley | 1 | $72.99 | $72.99 |
20145 | Power Steering Mount kit | 1 | $100.99 | $100.99 |
230106 | Earl's inline fuel filter, 6AN 35 micron | 1 | $40.19 | $40.19 |
12-803 | Holley Fuel Pressure Regulator | 1 | $37.07 | $37.07 |
15632 | Aeromotive fuel gauge 1-1/2", 15 psi | 1 | $42.70 | $42.70 |
661960 | Russell -6AN cap | 1 | $5.99 | $5.99 |
66-3040 | K&N Air filter | 1 | $199.95 | $199.95 |
85-3549 | K&N Air filter base | 1 | $43.95 | $43.95 |
670340 | Russell Fuel pressure takeoff adapter | 1 | $15.99 | $15.99 |
3.1117 | Energy suspension motor mounts | 1 | $54.71 | $54.71 |
Moroso Chrome crankcase air breather | 1 | $29.99 | $29.99 | |
SFI Flexplate | 1 | $75.00 | $75.00 | |
Total | $16,838.66 |
