1 - 10 of 10 Posts
I need help identifying these rally's and knowing how to proceed in restoration. Correct paint, etc. The center caps are the cookie cutter type. Any help is appreciated.
yup! they came out on like 71 or so novas and 72 or so camaro's
a friend of mine had those wheels on his used 1979 Camaro back in the day....I believe they are 14x6 Rally's....
As far as your 1968 I would go with a 14x6 Rally or 15x7 Rally if you want the correct look...Many companies offer the wheel already painted so all you need to do is mount & balance a tire and you are good to go.
Discussion Starter #8
I found some wheels coded: K 1 2 11 13 FW along the air valve hole
and on the lug nut hole area it reads: GM K 1 2 M
and on the inside of the wheel it reads: 15x7 JJ K 1 2
My search showed it looks like these are maybe to a Monte Carlo or FW 15X7 BS-4 1/4 71-up most any GM
Can anyone help confirm this code on wheels?
1 - 10 of 10 Posts
