Now that my rear suspension is done and the cars weight is on the springs again, it's time to think about something to connect the new rear to the TKO, hopefully permanently this time.
Looking for suggestions on a good place that can make me a shaft, for starters.
The yoke for my tko uses a 1330 joint.
The yoke on my 8.5" rear, I believe, uses a "3R" joint.
The holes in the yoke are threaded. All the hardware is missing. I've seen these before and believe it origianlly came with a flat metal strap and 2 bolts.
In an ideal world, I'd want a set of billet caps for this thing, with the strongest bolts money can buy. Where do I get them?
I'm figuring on getting a chromemoly 3" shaft with new 1330 yokes on both ends, and using a combo 1330 - 3R joint in the back. I want to use solid (non-greaseable) joints.
What brand should I get? Always thought spicer was best for this stuff, but a summit search comes up blank?
Discuss....
Discuss....
