1 - 17 of 17 Posts
is there such a product made for the 68 camaro UNDER hood cavities to fill them in.
when you raise the hood it looks like a large dog paw
You can get an insulation pad that covers most of the underhood.
I was looking up the hood insulation and found this.
[ATTACH type="full" alt="264024"]264024[/ATTACH][ATTACH type="full"]264024[/ATTACH]
I can’t say I have seen this before. Most of the time the insulation is molded or a blanket. They are held in place by plastic push rivets. These new insulation pads appear to just insert into the hood cavities.
Roger
Never seen that before but sounds like what he's looking for
View attachment 264024 View attachment 264024
Roger
yes sir that is what I am looking for. now to find them
thanks
I'm not real familiar with the underside of an SS hood, so what would make this exclusive to the SS hood? Visually it looks to me like it would work on a flat hood.
I did order them thank you for your info
I am not that familiar with the difference either. I did see the review in that link. It talks about not have enough room for the front of the larger pad. I looked for some underside pictures and they are attached below. The gray hood is flat hood and the red is a SS hood. If you look at the front of the larger opening of the gray hood, it does appear there is little or no room between the reinforcement and the hood top. Hope I didn’t mislead someone if they have a flat hood.
Roger
Brett - Leander, Texas 1969 SS396
Here is another style. Prolly more than I would spend, but it is still nice to see what all is available out there;
Brett.....
Dog Paw Fiberglass
Thanks Roger. I think the pads give a finished look. I'll investigate some more.
Edit: added SS hood closeup pic. You can see the forward lip of the large cutout. The flat hood does not have the space under the brace in that area.
Yes and you can see the flat hood is worse. On the SS hood it looks like just two reinforcements but the flat hood, no room all along the front.
Roger
1968 Camaro RS/SS
Hood Insulation Pad Fiberglass No Clips 1967-1969 Chevrolet Camaro Grey/Black
264124
I bought this one off fleaBay. It was $190, but it has great detail and really finishes off the underhood nicely.
264125
1968 Camaro RS/SS
A quick pointer on the hood insulation... The repro clips are kinda pricey and the thickness of the under-hood insulation I bought make them want to deform and break apart or fall out and get lost.
Solution: open wallet and buy a second set of plastic pushpin clips. Then, nip out the center with side cutters and install them with a longer replacement plastic pushpin through the center you just opened up.
264520
Discussion Starter #14
264525
the 4 small inserts fit like a glove. the large one required thinning at the top where the channel goes under the outer structure on both sides
Here is the one I bought. Quite different because it is for a cowl hood. After the pic I added the last two clips to hold up the pad around the cowl opening.
Brett....
265120
1 - 17 of 17 Posts
