1 - 20 of 21 Posts
hi I have a couple of questions > I am starting to do a up grade to my 67 camaro to electric windows and electric door locks .I have purchased everything allready from Electric life . I went thru me chassis book and my assy manual and i dont see a location for the hole to be drilled in the door and chassis for the wires to pass thru .
2nd if anyone has done this if you have any suggestions thanks ps ill probly have more questions after i get into it
Tony
I installed a hybrid E-L/factory PW setup in my '67 a few months ago using E-L lifts but GM wiring and switches. The rear windows operate at the normal factory speed, but the fronts are a little zippy. Plan on reparing the roller/guide on at least two windows.
The dimples are in the lower door jams. Look carefully or use your fingertips to locate them (they're there) and then use a hole saw per the size of your jamb boots. You will be removing the kick and door panels, so you get to locate the dimples from both sides of the jambs if necessary.
No power windows but I did install an alarm, and installed power locks w/ remote. As said, the dimples are on the doors between hinges, at least they are on the '69's.
chops I am allso installing power locks with the alarm and beleave it or not it seams more difficult could you let me know what you did ?/
Tony do it in 2 steps. First get the lock circuit installed and tested, then tie the alarm into the circuit.
I installed locks and alarm with remote entry in my Nova. The wiring will be dependent on the type of lock actuator the system uses. GM used 2 different styles, after market is different too. Mine are actuated through a polarity reversing relay so it is a little more complicated than a standard GM system (originally from an 82 Eldorado). My El Camino had an after market system that actuated by using the manual door lock knob so no additional switch was needed.
What brand of locks and alarm are you installing?
Discussion Starter #11
I thinks ? the info on the unit is vague the replacement number on the paper work for the remote is 95121 i wish the kits where solded together instead I ordered the lock actuators from yearone and when i got it there wasnt any wireing so i called and i had to order the harness seperate so i call electric life directly and orderd the remote kit
Discussion Starter #12
update
well so far i have the electric wondow and switches installed they work well , it took a little engering to mount the handle switches i should take some pics I have one door lock actuator mounted in the pass door ill get to the driver side i hope this weekend
Discussion Starter #19
thanks i am a little confused with the lock wiring the diagram with the actuators shows the blue and green wires come from the keyless entry and the keyless entry has a blue/black =com unlock and a green/black=lock but allso has brown/black =n/c,red/black=n/o,white/black=n/c,violet/black=n/c what the heck do i do with all thos wires?/
1 - 20 of 21 Posts
