1 - 2 of 2 Posts
Giving serious consideration to Global West tubular A-arm uppers to get more caster. I currently have 5.5 degrees with 1.5 degrees neg camber. Didn't do the Guildstrand mod since that was a little more invasive & irreversible to our matching-numbers Z.
Do folks have good experience with GW's setup, and what kind of alignment settings are you able to get. Realistically, I'd love to see around 7 degrees caster and 2.5 negative camber, but wanted to check with the wisdom here before pulling the trigger.
That seems like a lot of negative camber. What kind of use will the car see?
I would also worry about rubbing with 7 degrees of caster with stock lower control arms.
Don
Reactions: allanjs
1 - 2 of 2 Posts
