Hey guys,
I've got a '67 RS/SS 396/325hp w/Turbo 400 trans. The car did not have A.I.R. to my knowledge. The build date on the cowl tag is 05E or the fifth week in May. I just stumbled upon this service bulletin in the CRG carburetor info.
http://www.camaros.org/carb.shtml
As per the June 1967 Chevrolet Service News bulletin, the 7027211 carburetor was also installed on some 396/325 cars with automatic transmissions and serviced in the field by 7034589.
The service bulletin states:
Use of the manual transmission carburetor is an engineering deviation issued in May to incorporate the secondary throttle lockout feature of the carburetor on units equipped with automatic transmissions.
If such a unit is encountered in the field requiring replacement, use carburetor Part No. 7034589 [2nd Design service replacement listed for use on the 396 cu.in. engine - manual transmission.
My question is this:
If engineering issued this production change in May, and my car was built in the last week of May, when would the change have taken effect on the assembly line? In other words, which carb(s) would be correct on my car?
For one thing, I do not see the #7034589 carburetor listed in the CRG apllication chart. There is a #7034588.
Just to keep it simple, which carb ID tag would be correct for my car?
The 7027200 ID automatic carb or the 7027211 ID manual carb?
Thanks,
Buzz
When I purchased the car from the second owner it had a Holley spreadbore on it. This carb with a Mallory distributor, Hooker headers, and Lakewood traction bars were te extent of the mods made to the car.
I was able to eventually get the exhaust manifolds from the guy, but he said he couldn't find the carb or distributor. His brother doid all the work on the car so it may be he tossed them.
I am now trying to gather the necessary missing parts to restore the car.
Thanks,
Buzz
Hey guys,
Thanks,
Buzz
The key word being used by ORG. is SOME.
Looks like you can use the one you can find.
The Q-Jets where produced by Rochester and Carter.
1965-1969 Chevrolet by the numbers has good info on the subject.
I would use the manual carb and take advantage of the lock out.
Forget about the service carb.
I apologize for the 'urgent' in the heading, but I ran across a carb which I ended up buying. This very nice carb is has a 7027200 ID, which is for a 67 Camaro 396 cid with automatic trans and w/o A.I.R. I feel I will be happy with this carb and hopefully the date code will coincide with the car's build date.
I'm still in need of the TH400 kickdown switch and bracket which works off the carb's throttle arm. I need the whole works including the tab which attaches to the throttle arm. Anyone know where I can get one?
Thanks,
Buzz
