Would changing the inside diameter of a vacuum hose change the amount of vacuum supply to say a headlight actuator, assuming the amount of vac from the engine stays the same?
I hope this question is makes sense
1969 Camaro RS/SS 350
No, you stated vacuum source remains the same. So, flow would remain the same.
What will change is the velocity of the vacuum, if there is such a term. Smaller diameter, faster speed, larger diameter, slower speed, providing the source remains the same.
That's like asking "How much does a vacuum pump output?"............LOL
Everett
Discussion Starter · #3 ·
Thanks Everett. So if I understand corectly if I change the diameter of the Vaccum hose to my headlight actuator the only thing that will change is the speed that the headlight door opens.
