Hi guys! A little help, please. I desperately need a vacuum hose routing diagram for those nightmare headlamp doors on my `69 RS. I can get 'em to open with the light switch, or close, but not both! Also with a new regulator and new alternator, I can't get the system to start charging unless I excite the field wire with a momentary 12 volts. Can you help?? Terry
Terry you have email with the RS hose diagram
good luck
click
69RS 350/255 LM1, Balanced, TRW forged pistons, .30 over, TH-350 auto.,
Dover White,Blue Vinyl top, F&R spoilers,pdb, close ratio ps,am/fm,3.08 Posi., A/C, fold down rear seat
My RS www.brainerd.net/~knudsen/69RS
Welcome to the club!!!
On the charging system,
Monitor the blue wire at the alt plug, this should be the field voltage from the regulator. Shouldn't be more than 4 volts max.
Basically, what you are doing is full fielding the alternator, temporarily making the alt generate as much as 40-48 volts, just to warn you.
You may have to rev the engine up to 2500-3000 rpm to activate. Make sure the alt bulb works, as in comes on when IGN on, engine not running.
Everett "OBJECTS IN THE MIRROR DISAPPEAR UPON RAPID ACCELERATION"
