1 - 10 of 10 Posts
What is the best valve spring compressor for changing springs/seals with the motor in the car? To clear the brake booster, etc., do you need more than one type to complete the job? Thanks.
Lever type works ok. Auto parts store offer free loaners.
I use this one for everything as it operates with both 3/8 or 7/16" studs. I have a special short compressor I used when the booster got in the way. I don't see it anymore but its the one with the turning knob on top . I used it for the larger 1.625 big triple springs on the hemi cars, back in the day.
JEGS Performance Products 80521: Stud Mounted Valve Spring Compressor Tool | JEGS
Probable good time to check spring pressures and seals, if they are old.
Same as the one I have.
I have used this one for SBC heads and on hydraulic camed BBC heads:
https://www.summitracing.com/int/pa...la-google-_-shopping-_-srese1-_-proform-parts It is fast and easy to use, but doesn't like really stiff springs.
I also use the straight third class lever style bar (mine was from Moroso and cost $30 bucks or so back in the sixties), but I see has been copied and made off shore for a lot less:
Powerbuilt Valve Spring Compressor Lever-648546 - The Home Depot
Here is the one Don was talking about above; but I find it cumbersome, and often will not stay attached to a strong spring:
UNIV OVRHD VALVE SPRING COMP
Finally I have used my spring pressure tester to replace a weak spring without walkin' all the way back to my tool room to get the right tool when the wrong tool is so handy.
Moroso 62390: Valve Seat Pressure Tester 300-lb Reading Scale | JEGS
Big Dave
Discussion Starter #8
Quite a range in price; $14 to over $200. Looks like from an affordability standpoint the $14 one for the cylinders near the booster and the lever one for the other cylinders may be the way to go. Now I need to look into seals.
I've used both the Stud Mounted Valve Spring Compressor Tool and the Universal Overhead Valve Spring Compressor Tool with success. I'd recommend you wear a glove when using the Universal Overhead Valve Spring Compressor Tool or you can weld a spare 3/8" drive socket onto the center of the handle so you can use a ratchet to make it go a bit faster and easier.
I used the lever type to change springs on a BBC in a 69. Worked well.
Tried the screw type and it kept slipping of the springs.
1 - 10 of 10 Posts
