I'm having larger stainless valves installed alnog with new springs and was wondering if it is safe to use the old retainers and valve locks?
Can the valve seats be reused?
[This message has been edited by camarors1967 (edited 12-26-2000).]
rs (?),
Locks and even retainers are so cheap it does not make sense to reuse them...especially the locks. If the springs are stock diameter, you can reuse the stock retainers. The locks only cost a couple of dollars and should not be reused.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
rs?
I would never reuse the old retainers and lock unless you want to replace a whole motor because it dropped a valve after stripping the locks through the valve. Seen more times than I care to remember. Beside's it is cheap insurance.
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
