1 - 8 of 8 Posts
My 67 has single piston calipers on the front off a 70 chevelle. The master is original drum brake type with no proportional valve or any other valves for that matter. The system seems to work just fine. My question is do I need to add valves and change master when I add line-loc?
Discussion Starter #2
Anybody???? I see the lights are on, anybody........:D
No - all the line lock does is prevent the fronts from draining pressure. If your brakes work well now you can just leave 'em alone.
Thanks rod67ss. Just can't understand why they make proportioning valves and different master cylinders when "one size" seems to work all.
Since disc cylinders have larger resivoirs there must be some reason. Could be a temperature issue... or maybe just a bigger safety margin. Anyone know for sure???
I guess not:sad:
on a 4 wheel drum braking system all brakes apply the same pressure. on front disk to rear drum 60-40. 60 is on front 40 is on rear.you may not notice till you upgrade to disk brake master.and also put in proper pro valve.
Master cylinders have to have the correct piston diameter to move the fluid volume requirement of the system they are used on. Generally disc has a greater volume requirement than drum. Go to wilwood and other aftermarket brake websites and you can read to your hearts content.
A disc/drum combo should have a proportioning valve. There are even adjustable ones.
Usually the proportioning valves on OEM disc/drum combos also incorporate a residual pressure valve on the drums hydraulics, in order to keep a few pounds pressure on that system because of the heavy springs on the pads. Hope this helps some.
1 - 8 of 8 Posts
