:confused: heard there was a way to by pass vats system for your key. you know what the next question is...................how do u do it? i have a 1989 camaro rs. the security light keeps flashing on and off. i was told it was beacause of the vats system. i tried cleaning contacts and key with alcohol. already.- better but not fixed. if its easy to bypass i will do so. thanks guys:thumbsup:
if you read the resistance in the key chip with a dvom, you can get a resistor from radio shack of the same value...connect it to the wires that come off the key tumbler, and you`ll be good to go... the tumbler wires are white i believe...and in the column...
