1 - 14 of 14 Posts
My engine vibrates pretty bad, i had the all the bearings done with new piston rings. When i put the engine back in i used new engine mounts, old ones were pretty bad. then i put a new dual friction centerforce clutch had my hayes flywheel resurfaced. Got my car running and it seemed like their was some vibration in drivetrain when i took off in first hard, or at higher rpms in any gear, so i did my 500mile break in, changed the rubber tranny mount with a new energy sus. mount. Started the car and drove it, it shakes and vibrates pretty noticably and bad. It does it while it idles to, and when you put the clutch in it doesn't go away, my balancer seemed a little woobbly so i put a new one on, no good. Check spark,timing, everthing checked out okay,what could this problem be, it was never there before. Engine shop said the engine looked like it had been balanced before, also looked at flwheel/clutch through inspection plate while egine running and it looked pretty smooth,same with balancer, could this be normal with stiff mounts? it doesn't seem right, Maybe valves aren't adjusted it seems to idle pretyy smooth, (while looking at it, not sitting in car) any help is gREat.
try checking spark plug gap maybe you got one w/electrode bent or ceramic cracked also check the dist cap sometimes a cracked cap will cross fire under load but not at idle. check to see if you got your dist 180 out it will run this way but runs funny.
Discussion Starter · #3 ·
I have a brand new msd cap, i checked it earlier, it seemed okay, also had checked gap, they were all at 55 took them down to 45, which i believe is okay because i have msd box,coil, I also don't believe that an engine would run at all 180 out, could be wrong though, could definetly check. Could having a different harmonic balancer really make a difference? if i had the wrong one, would it make everything shake that bad?
Discussion Starter · #4 ·
Could my flywheel been out of balance when it was resurfaced, do clutch's get out of balance???
Check your water pump! I had a similar exprience chasing vibration. Loosen the belt that drives the water pump, grab the fan and shaft and wiggle it. If it wiggles the bearing is bad and will transmitt vibtarion. If you ever had belts flying off and corrected it by overtighting the belt, you may have a damaged the bearing in the water pump .
its worth a look before you tear into other areas.
We need more information. You don't say what this engine is. Is it a 383 or 400 that uses the counterweighted harmonic balancer and flywheel? Did you get the same flywheel back that you took into the machine shop? What RPM is it worst at? Is it smooth at any RPM?
What new engine mounts did you install - rubber or poly? Poly engine mounts along with a poly trans mount is a recipe for transmitting vibration to the rest of the car; the original mounts are rubber for a reason.
JohnZ
'69 Z28 Fathom Green
Discussion Starter · #9 ·
They are new hard rubber engine mounts, poly trans mount. Don't think its a belt, starting to think its flywheel/clutch, only thing that seems reasonable, how likely is it that this could be it? do you have to balance the fly,clutch a lot? or is it usually fine without balancing? its rough at all rpms especially down low, its an internally balanced engine. it has the most vibration when driving, and my brand new rearmain seal is leaking. and my tranny ouput bushing was messed up before i put everything back together. (had replaced, also polished input on yoke!
If your rear main seal is leaking you could be getting oil on your flywheel, causing the pressure plate to slip. This could definitely cause vibration. I would fix that leak for sure.
Let me give my 2 cents.....
Yes, one should balance the surfaced flywheel. You have changed the balance of it. At the same time, take new clutch plate and cover, have them neutrally balanced as one unit. Hopefully, machine shop would mark each place so as it can be assembled in same matter.
It would be even nicer if you still have the balance sheet from engine, this way it can be determined if those were neutrally balanced.
Vibration will cause the rear main seal to leak, I know you don't want to hear this, but, out-of-balance will also destroy the rear main bearing. Think of an out-of-balance tire.
Discussion Starter · #13 ·
Thanks, I only drove the car 500 miles with the new bearings, i hope that didn't mess the rear one up, Just today i took the flywheel,pressure plate to be balanced, thanks we will see if that takes care of it?
Discussion Starter · #14 ·
Just got it back together, most of the vibration went away, still a little rough not nearly as bad, does it for me, thanks for the info.
1 - 14 of 14 Posts
