The VIN #'s on my 69 don't quite match, that is the dash plate and the one on the firewall. Is the VIN # located anywhere else on the car so I can check as to what the correct # is? Any hidden place?
The partial VIN last numbers should match those of the cars VIN. if you had a 69 it would be 19nXXXXXX if it were a norwood car and L for Los Car. Not sure if the partial VIN would be VN since i have never seen one like that. Also look through the cowl panel below the passengers side windsheild and there is another partial VIN stamped there you might need a flashlight to see it but its there.
Jeff 67/68 & 69 RS's
65 442
http://hobbystage.net/camaro/hawaiiancamaro/index.html
