1 - 2 of 2 Posts
Anyone have any experience with those repair kits where you mix up a batch, fill a crack and use a heated tool to cure the filler?
These used to be sold on late night TV, but I bought one at Auto Zone the other day. I have a couple of minor nicks in an otherwize perfect original door panel.
They work OK. I used one for the same type of repair. The gloss of the repair material after it's been heated isn't all that close, so be careful how much goop you put on. Also, I found that I had to repeat the heat/application process a couple of times before I got a good set.
-Marc
1 - 2 of 2 Posts
