Is a vinyl top(roof) removable and in such a way that nobody can tell it once was a vinyl top?
If so, what does it take to do this.
David
I don't suffer from insanity.....I enjoy every minute of it!
'67 camaro SS (1:18)
'68 camaro SS (1:18)
'69 camaro RS/SS (1:18)
'70 chevelle SS blown (1:18)
only $2400 away from a '67 RS (1:1)
[This message has been edited by DL (edited 12-24-2001).]
I think they are put on with adhesive and there are some mouldings that also help hold them. I guess you would have to strip and repaint after removing the vinyl. I believe you can buy something that will soften the adhesive and then you can peel or scrape the vinly off.
I took the vinyl top off of my '69. I had to grind off the studs that held the trim on, but you can't tell now that it ever had one on it.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
And the metal under a vinyl top is not finished, it requires Extra bodywork to make it smooth, + you never know the condition of the roof untill you remove it. I like a vinyl top now, I used to hate them, but there are not many because everyone cuts them off...
Chris's 67 RS 327,can be seen at http://www.67rs.com
check out another site once in a while! http://www.fbodyconnection.com
Discussion Starter · #6 ·
Thanks, these were the answers I wanted to hear!!
David
'67 & '68 camaro SS (1:18)
