hey guys just wirering up some of my gauges. just wondering for my volt gauge what would be the best place to hook this up, the car is a 1982 cutlass with chevy 350 . and I was also just wondering how you read the gauge? were should it be pointing when the car is running? thanks in advance
Re: volt gauge
You could plug into the Power Convenience panel next to the fuse panel and find a blank spade having either IGN or ACC power to one voltmeter terminal and the other terminal to a good ground. If meter reads backwards, revewrse the leads on the meter studs.
With key on, engine off, battery voltage will be indicated.
Engine on, charging voltage, 13-14.5 volts.
Re: volt gauge
ok thanks alot I will try that , my charge batery light kept flickering on and off while the car was running any ideas why?
