my wife has 2001 camaro convertible......
when it rains she gets water in rear floorboards...
i know there are drains that must be clogged causing water to come inside cuz top is showing no signs of leaking...
can someone tell me exactly where the drains are so i can check them to see if they are blocked???
please help.....thanks
jeff
Re: water in both rear floorboards
My 2002Z did this. The rear hatch is designed such that quite a large amount of water will accumulate around the hatch opening if the car is parked on a nose down incline (such as in my driveway). The water would get nearly 4" deep in there and make it's way past the seal. GM eventually recognized the problem and bent the pinch-weld the seal is attached to to make it close more tightly (too tightly in my case). Also, I always back my car into my driveway so the water runs out instead of accumulating around the hatch.
