1 - 2 of 2 Posts
On my 69 Camaro I have a water leak in the trunk. The rear glass has been pulled and resealed. the trunk weatherstripping is new. And the gasket around the tailights is new. I tested the weatherstripping by running water the top corners where the trunk meets the body. No leak. then I tested the area between the top corners. No leaks. I then tested the chrome moulding the same way. I tested the corners. No leak. But the area between the corners on the moulding I have a leak. The leak seems to come down and then drip on the body seem next to the trunk lid arms. I can see the water drop but part of the trunk inner panel gets in the way. Is there a weeping hole that may be plugged or could there be a pin hole where the moulding attaches to the glass and body. Any suggestions.
Jerryt
1 - 2 of 2 Posts
