Camaro 1968, going along with a propane powered BPE 383 ci, T56, Eaton Posi 4.10:1, MCB Big Brakes
hi
we need new weatherstrippings for the time we will paint our camaro. But there are different weatherstrippings available, for standart interior for use with 1 1/2" outer door molding or not. I don't know which is the right to take between those 2 choices. Can you tell me where i have to look to know if my car has the 1 1/2" outer door molding option or not?
I took some pictures also, so I can send them to you if you want to help me.
Thank you.
actually, the door molding runs from the front edge of the door, to the back edge of the rear quarter window, on the outside.(2 pcs) it gets from about 1" at the front to 1 1/2" at the parting line between the rear of the door and quart. panel, back to 1" at the rearmost part.(quarter window) if you dont have this, then it will be just a small chrome bead attached to the weather stripping. hope that helps
