your fuse box is all filled up with add on electronics, tach, fan, distributor coil, lights...
i need to add a seond fan and the terminal i need is being used by the tach and the other fan. just conneting it to the battery is not an option.
any ideas?
-thanks
AAW has an upgrade kit that uses newer style fuses.
It can be used to replace the old fuses, add-on or run a parallel circuit.
Call Donny at AAW
Tell him Team Camaro sent you..
You can also bring a hot wire off the starter and add another fuse panel. Be sure to use a large enough wire to power the panel. Nobody likes a fire.
any ideas?
-thanks
You should be using relays for any high draw items, like fans. If you are using relays, the switched side pulls very little power.
http://www.camaros.net/forums/showthread.php?t=86707
