Alright the camaro i just bought have a big cam in it and i was told it was a "wolverine blue racer" valve 488 488 cam 325 326 duration 300. I tried looking it up on the internet but failed to find it if anyone could tell me how much HP these cams add id appreciate your reply. im thinking 15-40 HP
I think your asking "how much hp does this cam add?". Well, it all depends...it depends on what you are comparing it to and it depends on the rest of the combo. Do you by chance have the part number for the cam?
If you go to www.shopcranecams.com you will find the Blue Racer cams. As far as what HP increase you're going to see, you didn't even tell us what engine it's in. A big cam in an otherwise stock engine can often be worse instead of better.
Banned
Should be Crane/WBR's PN WG-1079. Spec's are;
292/232/300/234, 108/106, .488" lift hy-cam.
Imho, a hy-cam like that needs a minimum of at least 11 to 1 CR to run like it should!
That's a big cam in a SB unless it is a 400 or 406 motor!
And I have a Melling 292/230, 109/107, 480" lift hy-cam in my about 9.5 to 1 CR. 406 and it was doggy until I was up at least 25 to 3000 rpm!! (WBR's PN WG-1011)..
But once I was "up on the pipe" as the 2-stroke guys say, it ran fine even with my M-20, 3.31's and 26.5 tall, L-60 tires...
pdq67
its a 1969 camaro 327 with 11:1 pistons as most of you may have seem my 11:1 piston post. the car has over $4000 in recipts on the engine alone.Were thinking it has about 325-350 HP once we have the time we will have it dino'd for sure. I know that the original 327 engine on 68-69 did come stock with 275 HP, if that is of any more help to you guys. Thx for the replys and still looking for amoutn of HP added.
Banned
Post the rest of your motor's spec's and I will run it through D2K tonight after work and post back what it sim's at.
All it will be will be a sim., but it is at least a start.
pdq67
