1 - 10 of 10 Posts
I have a '67 Camaro 12 bolt with 3.08 non posi. It has a bracket for the traction bar and I am told this is a high horse 350, 396 or Z28 rear. First off, am I correct? Secondly, what is it worth?
Fan of anything that is interesting and moves human beings.
1965 Buick Gran Sport Convertible
1965 Buick Skylark H/T
1948 Chevy PU with 401 Buick
12 bolts were used on all SS and Z/28, regardless of HP, and I think, high horse 327. Two things lower the value of yours. 3.08, and non-Posi. Condition is the overriding determiner of value. If it needs rebuilding, I'd guess $400.
I believe the 12 bolt could be had with a 327 like Unreal said... if it was an L30 motor backed by an M20 trans. Other than that it was an SS or Z28 as far as I know.
surprised with the gear, 3.08,and open,
prob was a later build date '67.
The 12 bolt was available in later build date cars as an option,with the 4 bbl 327
{275hp}
From what i read here on this forum,the
smarter way to go seems to be to use a early
'70's Nova {Apollo,Omega etc..} 8.5 10 bolt
so unless someone is going for "origanlity"
it may not be worth quite so much..
'67 RS/SS 427,4 Speed
Disc brakes,console, fold down rear seat,heater,
Radio Delete, Cowl hood,front,rear spoilers,
Black/black white bumblebee stripe
Discussion Starter · #6 ·
Thanks guys, tell me, where do you find the date code on it?
Discussion Starter · #8 ·
Is it right over the spring pad? I see a number but it is going under the ubolt and is hidden. If this is the number, I'll remove the bolt and get a good look at it.
Thanks guys.
Last fall I paid $450 for one similar to yours, and needs a complete rebuild. Mine is also from a '67, with the traction bracket on the passenger side, but it has the 4-series posi carrier. I've been told it was a good deal. Hope this helps.
1 - 10 of 10 Posts
