1 - 14 of 14 Posts
This rubber capped wire is screwed to the tail pan of my car near where the right side fuel strap mounts. It's cut - and obviously not doing anything. My license plate light works so it's not for that.
Any guesses??? I'm stumped.
Here's what it looks like front the back of the tail pan. The bolt is for the fuel tank strap.
Front under the car facing the inner tail pan
Close up from directly under the tail pan
Any guesses?
Can you trace down where the other end of that wire goes. Could be that they wired in a reverse wire by pass.
I'm saying air shocks also. That nut that's painted red used to be a fill valve, the end of it is cut or broken off. I think if you take that nut off the "wire"will go away along with it.
Jeff
Air Shocks have hard plastic lines that could be misstaken for a wire. I bet there is no conductor in the wire.
Roger
Flux Capacitor, looks broke having any trouble with your time travel lately?
I say its parts from a toyota Prius after it falls apart on the highway?
They bounced up and stuck under your car?l:)
1 - 14 of 14 Posts
