#GabrielHiJackersI appreciate the dropped road-racing look. It’s cool.
But, my dna still wants to see the a$$-end up! lol.
...can't help but put a smile on your face!once upon a time, it looked like this or you were driving a grocery getter....... View attachment 301026
Factory shackles are 3 and 1/8 inch center to center.I have 5-leaf springs on my 68 RS/SS with a 350.
I replaced all the worn-out bushings on the back end with Detroit Speed Urethanes and their H-D Shackle Kit.
The Shackles I removed were homemade and were 3-1/8" hole-to-hole for length. The Detroit Speed's are 3-1/2" hole-to-hole.
Currently, my car body sits 7/8" higher in the back then it does up front.
What was factory for stance?
That is great information found nowhere else I know.Factory shackles are 3 and 1/8 inch center to center.
Here is an NOS one. View attachment 301047 View attachment 301048
After a twenty mile trip through town and parked for a night...After following along, I measured mine (less the hood) and the front was 8.5 and the rear was 9.25. I like that .great info guys.
Is this pretty close with all the options you have on the car?After a twenty mile trip through town and parked for a night...
Springs are a finicky lot - got me second-guessing my measurements! I checked a few times.
When you assembled the rear springs, did you bounce the rear end a lot before tightening the shackles?After a twenty mile trip through town and parked for a night...
I ran the numbers using the AIM.Is this pretty close with all the options you have on the car?
I did not.When you assembled the rear springs, did you bounce the rear end a lot before tightening the shackles?
Those are all good points. I used the “shipped” column in the AIM which just has a couple gallons of gas for a requirement.I didn't see this in the any of the above discussion posts, but you need to be on level ground, for curb weight a full tank of gas and 24psi tire pressure all four per AIM. JD
Pretty sure close enough looks good enough today. I do believe shipped cars were 1/2 a tank of fuel.Those are all good points. I used the “shipped” column in the AIM which just has a couple gallons of gas for a requirement.
I certainly appreciate your insights into bias, ply, tire construction. I don’t have any personal first-hand experience with those tires.
I started thinking the same thing with the bias-ply tires. Ultimately, my question was only about stance. With all four tires originally being the same but of a completely different profile I won’t get a number for exact vehicle height - but, I will get an idea of how the car might have sat.
it appears slightly nose up off the assembly line and now tail up 55 years later in my garage.
Agreed. That car looks fantastic!Stance is fine to me. I could stand a little lower in the front myself, but I think it is a 70s thing. View attachment 301061
Stupid autocorrect..lol..View attachment 301067
There are so many different ideas about what looks good, too. Original? Dropped? Rear-end Up?
IMO - doesn't matter, your car sits dang near perfect in my book, I like some gap at the top, to me looks aggressive.What was factory for stance?
Thanks!BFG doesn't list a 265/50 that I found.
Interesting, my measurements are exactly the same as this post.After a twenty mile trip through town and parked for a night...
Is your suspension new(ish)? or, more original?Interesting, my measurements are exactly the same as this post.
