Just for info:
I used the original '67 (V8) Radiator in my car when I did the '97 LT1 swap.
I took it out, and had a good rad. shop clean it and core it. I also had the extra nipples added for the extra coolant lines.
Spent a total of $50 for this service.
I use an electric fan from a 1991 Chevy Citation (it's a very heavy duty fan).
It works off a 190 degree switch in the block.
Four years so far with no cooling problems.
In the heat of the Arizona summer I see at most 240 degrees at stop lights (which is what my '96 Impala and '94 Vette did as well).
When moving, the car stays around 190 in the city and 180 on the highway, no matter the outside temprature.
I also wired in an override on/off switch under my dash in for those extreme conditions when I want the fan to keep running, such as at the track between runs, etc..
Cheers,
David
