1 - 19 of 19 Posts
Guys I am looking at building a 496. Here are the specs of the heads and cam:
Heads: Edelbrock 60459
BB-Chevy Performer RPM Aluminum Cylinder Head
290cc Oval Intake Ports
110cc Combustion Chambers
2.190'' Int/1.880'' Exh Valves
1.550'' Valve Springs, .700'' Max Lift
7/16'' Rocker Studs
Cam Kit: Edelbrock 7162
Cam and Lifters, Hydraulic Flat Tappet, Duration 300/306, Lift .560/.573, 112 LSA
I am going to bore it out to 4.310 and stroke it to 4.250 to make a 496, but what type of pistons will I need to get a good CR? I will be using pump gas 91-93 octane and it will be driven mostly on the street (m21 trans). Thanks.
Since we all like pics..
What size rod are you running? A low profile dome piston is what you would be looking for. Assuming your running a 6.385 rod the following will work:
KB787 = 10.2-10.3:1 Compression
SRP #145376 = about 9.8:1 Compression
-5cc - -12cc dome will be in the range you want.
I would wait until alll the machine work is finish.
Im running these SRP Forged slight dome in my 10.5 BBC 498 pump gas
Scat Forged Crank
Scat Forged H-Beem Rods
Im running these RMP's Forged slight dome in my 10.5 BBC 498 pump gas
Scat Forged Crank
Very Nice...whats your combination? Im just wating for my heads from AFR to finish up so I can dyno my 496! :hurray:
Thanks for the advice. I will wait for the machine work to finish and I will see what they say. I will see what they say for rod size as well.
thanks.
How about a much better cam...you are doing a disservice to those heads and cubes with that cam choice. I'd like to see more lift..alot more.
Picked out a crank and h-beams, and the rods are 6.385. Might be a dumb question, but do these pistons come with rings? I am assuming all pistons come with them, but thought I might double check. Also what is better internal or external balanced crankshaft?
http://www.summitracing.com/parts/UEM-KB787-060/?image=large
Thanks.
They will not come with rings, you will have to purchase them seperatley. I would go with what the manufacturer of the pistons recommend. Get your whole rotating assembly INTERNALLY Balanced. If you purchase it already balanced through Scat or Eagle, I would have your shop double check it as they are not always dead on.
Did you already purchase your rotating assembly?
Discussion Starter #11
I haven't purchased out my rotating assembly, but I was looking at internally balanced forged Scat.
The cam is part of the top end package, but I can always go with another one. Anyone recommend a better cam?
Ill send a picture of my build sheet, which we changed cams to a comp cam solid roller XR286R on a billet core with a pressed on gear. 254 @ 50 AND 660 LIFT 110 LS.
Scat is a good way to go. Kit #1-42310BI is what you would want with a .060 piston. It will most likely come with a Mahle piston, sometimes JE or SRP. You can request which one you want as well. all are a great piston. I can help you out on pricing if you'd like. Shoot me a PM if your interested.
I just finished a 489 inch race engine using an Eagle kit.Then you pay the extra 200 bucks for the balance job,they do in fact balance it.I used the kit with a 4340 crank and H beam rods,it came with MAHLE 18cc dome pistons with metric rings placed low on the piston and a valve notch to clear .750" lift.This setup is designed to give a true 10:1 with 118cc heads,zero deck and a .035" gasket.I will be running it with a .720 lift cam and the heads are milled to 110 cc's,whch will bring the compression up,and it will be shot with a 250 shot of nitrous as well.I figure about 1000 hp total,this kit will give you 10:1 compression and should be more then durable enough for your combo.The kit including balancing was $2200.BTW,thats an internally balanced kit.
That sounds like a mean machine... Take some picks and a video:yes:.
1 - 19 of 19 Posts
