1 - 20 of 98 Posts
Hello, I’m ordering front sway bars soon for better handling. And also thinking of replacing the front tires from 235/45/17 to 245/45/17 (keeping rears 275/40/17)
I’m also looking to lower the car a little? (Looks like I have some room, right? photos below)
Question: What suspension kit & other parts do i need to replace my current suspension or springs? If you could please send me links of suggested kits along with any complimentary components needed with it
Note: the car was purchased from a previous owner so i dont know what suspension work has been done to the car. And i have no contact with the person anymore. Thank you
Sent from my iPhone using Tapatalk
Discussion Starter #2
Help identify Shocks , Springs (68 Camaro)
Bought my 68 way back from a previous owner who rebuilt it - Restomod. I have no contact with him, and I'm trying to identify some of the parts below:
1) What KYB shocks are these?
I think the fronts are (KYB heavy duty ) Click Here
Front:
Rear:
2) Which KYB shocks are my rears?
From the looks of it, i have multi-leaf springs. Is that correct?
I found 2 types of KYB shocks (Mono: Click Here / Multi: Click Here)
3) Is there anyway to identify what brand/type of Leaf & Coil Springs I have?
Thank you very much.
These are my current shocks, coils and leaf springs (started another thread helping to identify the parts)
Thread link: CLICK HERE
KYB "gas-a-just"....https://www.ebay.com/itm/For-Chevro...703237&hash=item2339f877ff:g:0CsAAOxyBotTaOmK with multi-leaf springs. A very STIFF set-up...
Thanks for the info. Yeah its stiff and rear leafs are wearing out. The ones you sent are gray vs the ones i have in white (like the link i have above) or is it the same just color difference?
I dont know what coil springs are on, if I were to replace the coils & leafs, What should i go with?
Put a full Ridetech Street Grip kit on it and call it done.
Don
Don
Hi Don, thanks for getting back. Is this the kit you're referring to?
https://www.ridetech.com/products/streetgrip/1968-1972-gm-a-body-streetgrip-system/
It's a little over my budget now, since i plan to go with front sways, maybe Helwigg, for now. And also not sure if my KYB shocks should be replaced or not.
Trying to figure out what coil springs I have on the car, and the ride height. I plan to go a little lower since it looks like I have some room/gap.
I currently have 235/45/17 & 275/40/17 --planning to go 245s up front
You have spacers stuck in the front springs. Put there I’m guessing to raise the front.
I’d start by taking them out.
Appear to be stock springs front and rear. The front coils may have been cut at some time and could be why the spacer was installed to stop running if they were cut too short.
Discussion Starter #9
Is this the spacer you're referring to?
if they're stock, then I might go with new coils with a little lower drop with some room left to avoid rubbing if im going with 245/45 in the front.
My leaf springs are also worn out.
So my question is: If I plan to just get: Front Sway + Multi Leafs + Coils
-Which would you recommend?
-What drop would be good? Front/back?
-I have KYB shocks, will any of the parts i want fit with those shocks or would i have to change that too?
Thank you
Personally I would wait until I could do the Ridetech StreetGrip.
Anything else and using parts are not engineered to compliment each other may be a waste of $.
You could go Hotchkiss frnt and rear springs and Front sway bar along with a good set of adjustable shocks.
https://www.hotchkis.net/product/19...ont-sport-coil-springs-2-in-drop-small-block/
https://www.hotchkis.net/product/19...in-drop-also-fits-68-74-nova/?mk=&yr=&md=&sm=
https://www.hotchkis.net/product/19...om-hotchkis-sport-suspension/?mk=&yr=&md=&sm=
https://www.hotchkis.net/product/ho...k-67-69-gm-f-body/?mk=47&yr=1969&md=432&sm=20
Or better yet the complete TVS for $1600
https://www.hotchkis.net/product/19...-sport-suspension/?mk=47&yr=1969&md=432&sm=20
Reactions: Just 1 More
I you lower the car, 245's can cause some rubbing issues. The suspension depends on how you drive the car and what is your objective? Why do you think the rear springs are shot? I would install stock or 2 inch lowering springs from Eaton spring company. If you contact them, they can advise what you need. Monroe, Gabriel or Delco HD gas shocks are not as stiff as the KYB or many of the after market shocks. . . . .and they are more reasonably priced, check with Summit, they may help you with everything you need at your budget.
Discussion Starter #12
Appreciate the help. I'll take a look at the links
Discussion Starter #13
I'll be street driving only, no track/drag/auto cross. I just had an alignment done, and mechanic said the rears look worn out. Also, rear right side sits lower than left.
I have the KYB Gas Adjust shocks like yours all the way around on my '69. The ride is firm but not harsh. The car had new front and rear springs, I think they'r stock when I bought it. I added a 1 1/8" front sway bar, with this combination I feel the car handles great, fun to drive and not uncomfortable.
Discussion Starter #15
Shocks feel stiff, like hard when u hit a pothole.
Anyways for now I might just stick with new leaf springs 1.5” drop and front sways and see how that goes.
I would start 1st by removing the spring spacer in the coils. If the car the sits too low change the springs.
Reactions: Parkerized
68 RS L30 AA 749
Re: Help identify Shocks , Springs (68 Camaro)
Yes, gas-a-just are white or originally were. I have a set that I replaced as they were too firm for my liking. It may just be the online photo making them appear gray...
Get a Hotchkis TVS kit or Ridetech street grip kit. That would be the easiest all in one kit with one set of instructions.
I had a complete Hotchkis lowered kit with ridetech shocks, I thought it was great for spirited street driving,even a little autocross.
When I first put my car on the road 3 years or so ago, I put brand new KYB Gas adjusts on, no exaggeration, I removed them after a few laps around the block. In my opinion,I think 4 bags of gravel may have been a better choice.
I replaced my shocks with Gabriel HD gas shocks for a hundred bucks, better ride than my KYB's Try em . . . you'll like em if you don't want to spill your coffee!!!!! I figure if 90% of new cars have Gabriels(according to them)my as well try em on the old 69 RSSS BB lowered with 17's
1 - 20 of 98 Posts
