I'm looking at getting the Ramjet 502 as soon as it's available. What would be a good standard transmission fot this motor? It puts out 510hp and 550ft/lb. The car won't see the track. It will see less than 3000 miles a year. I would like a 5 or a 6 speed. Anyone here anything definite on when the motor will be available? I've been told January or March. Thanks.
My car: http://albums.photopoint.com/j/AlbumIndex?u=424666&a=3131121
I looked at the info for the Ram Jet 502 Dec. '99 on my way back from Ohio at Jim Pace Gm Center. I was told Feb '00 they would be available. Well, when Feb. came and went I buoght the ZZ-502/502 with the 850 Holley. It has the 502hp with 567lbs of torque. I had the car on the road for 3 1/2 months this year and what a blast. I just didn't feel like sitting around waiting for a couple more hp's.
Sorry I can't help with the shifter, I have the T-400 from Hughes in Arizona.
Make shure you have a good radiator, I went with the 2 core Griffin. 1 1/4" each.
69 Coupe LeMans-Blue
Frame-Off Resto, ZZ-502/502 Crate, A/C, Griffin Rad., March Serpintine Sys., 2800 Stall with Hughes T-400, Currie 9" with 370 Gears.
http://www.geocities.com/mobiletools1/Mvc-440f.jpg
Jim Pace GM add in carcraft jan 01
has them listed at 7195.95
1-866-875-5870
I've started saving already!!!!
I would have to have a 4spd. my self
m22 ?
stock? 67
69BB in resto.
Maybe a Richmond 5 speed or a Tremec TKO (5-speed with OD). Both of these trannys have been installed by members on this site and should handle the power level you want.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 12/17/00 at:
www.geocities.com/gheatly
The tremec TKO should hold up to that kind of power and is supposed to be direct bolt in, even with a factory console. Check out http://www.fortesparts.com/tremec/tr3550.html for more info and also do a search here. Good luck.
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
Discussion Starter · #6 ·
I emailed Jim Pace. I was told that the rumor is that the Ramjet 502 might be available in Jan 2001. The guy recommended a Richmond gear transmission.
Thanks for the feedback.
