1 - 13 of 13 Posts
I thought for sure that A/C was not available in the Camaro Z28 until around 1973 or so.. The reason that I ask is: http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=595870750
This car shows to have A/C. Perhaps the owner added it? Or is something not quite right here? I was also concerned about this statement in the description:
The seller said you will not be able to pick the car.
What does that mean? I will wait/watch for replies from some of the sharpest minds on the net.. Have a great day!
1969 Camaro SS 350-383ci./365HP, T-56, 12 bolt, Power Trax Locker, 3.73 gears, 4 whl disc, Deluxe black houndstooth interior, rear window defogger, tilt steering, floor console w/gauge package, center mntd. clock, tachometer
The statement that none of the 1st Gen Z28s had A/C is true. I "think" in 1970, that a Z28 could have had A/C. Go to our brother site for 2nd Gens and check it out.
Some might not like the fact that it has a Tremec in it from the numbers perspective. The flip side is you get overdrive. WEEEEE!!!
Rick-O
I think it was '73 because '73 was the first year the Z didn't have solid lifters.
'69 RS SS 396 375hp L78 Convertible, M22, 3.31 posi, deluxe interior, gauges, rosewood wheel, AM-FM,fold down seat, tilt wheel, Torque Thrust Wheels, console mounted 8 track player, chambered exhaust
http://albums.photopoint.com/j/AlbumIndex?u=1169124&a=8603468
G
All my info claims that 1973 was the first year that it was offered in a Z28, plus I own a 73 Z28 that had A/C at one point in time.
Mark (A.K.A. Z28 Mark)
I don't care for all the "the owner said"'s
It's kinda like don't call us when you find something wrong!
Yup, 1973 is the 1st year Air was available in ANY Z28, due to the non-solid lifters among other things. Plus, a 4 speed Z28 with air forced the wide ratio M20 as opposed to the M21 close ratio trans.
Finally, you can't (easily) swap A/C from an ac car to a non-ac car. Unless you punch open the firewall and substatially change the under dash ducting, venting, wiring, the dash itself.....
Sounds like the dude got caught on the A/C issue already. I'll bet the car also has the "rare" trim tag that doesn't say Z28 on it - like (almost) all the real ones.
That's tough - it could be legit (because the original engine is apparently still there).
[This message has been edited by NastyZ (edited 09-27-2001).]
1 - 13 of 13 Posts
