I'm looking for some ideas on how to repair this wobbled out hole in my sub-frame that holds the right lower control arm. I was thinking of welding a washer over the hole but thought someone might have a better way. Thanks
This is common...
I wouldnt trust washers. Couple 3 or 5mm plates instead welded in place...can weld over or cut the hole back to good steel then but weld in place and dress up so looks orginal.
Maybe weld up the oblong section then file till back to original shape. Maybe get a copper piece in there somehow to keep the backside flat and fill with weld??? The copper should give you a nonstick backstop.
