1 - 2 of 2 Posts
There are several problems with my instrument panel and i would like to remove it. However i can only pull it out a little ways befor it is wedged between the frame of the dash and the steering column. Is there a trick to doing this without removing the steering column?
thanks,
You don’t have to remove the column, just loosen the three nuts all the way and drop the column down a bit. That should give you enough clearance to remove the cluster. If not, remove the nuts and let the column down farther.
1 - 2 of 2 Posts
